boot lid problem
Zach54
clk 320 cabriolet
I have a w208 320 clk cabriolet 2000. the boot lid has stopped working from the interior switch and the remote. U have tried the metal key which will not turn either way. I have also tried lubing with WD40 to no avail.
Help does any one know how I can get into the boot. I am coming to the conclusion that the boot lock does not match the key.
I recently had a flat battery and had the same problem with getting into my boot!! anyway If Im right there is a fuse which operates both the boot release and alarm on the 320?
Thanks for your reply, but the battery is fine.
have the same prob with a clk 230 and yes i had a flat battery any ideas the key dont seem to work
Email me and I will tell you
The fuse that you mentioned is in the fuse box in the engine compartment or in the one in the boot.
Blackc55
Just dropped you an email thanks bud
