Hello All,
Had sometime today so went to check on the car. I didn't check the boot of the car when I purchase it, probably a big mistake?!?
The boot closer end of the boot seems to be rusty, but it has not rust through or anything, just some surface corrosion. I then pursue to look underbody, which I did before and it seems to be extremely clean, the waxoyl is still doing a good job. Just wondering where is the water ingression coming from? I use to have a Ford Mondeo and that came from the rear lights, would that be a likely case? It seems that the rubber around the boot is good?
Thanks,
Angus
Thanks,
Angus
