They seem to produce awesome work. Want to try them someday soon.
Used them to do a set on mine. Paintwork redone several time as their painter seems to struggle applying a straight line template against the caliper. Forget about the whole 'rebuilding' process. Brake pad guides holes never tapped after being spayed. Bolts tightened half way. Dust seals not seated correctly. Single worst experience I have ever had with a so called professional company.
If you must use them... Dismantle your calipers, takes them apart, replace the bolts and seals yourself, just hand them the bare pieces for spraying. I wouldn't trust them with the rebuild, too dangerous.
Alx said:Used them to do a set on mine. Paintwork redone several time as their painter seems to struggle applying a straight line template against the caliper. Forget about the whole 'rebuilding' process. Brake pad guides holes never tapped after being spayed. Bolts tightened half way. Dust seals not seated correctly. Single worst experience I have ever had with a so called professional company. If you must use them... Dismantle your calipers, takes them apart, replace the bolts and seals yourself, just hand them the bare pieces for spraying. I wouldn't trust them with the rebuild, too dangerous.
They did the whole job, remove, strip, paint in high temp paint mixed to match any colour, rebuild with new seals, pins, bolts etc, refit, new fluid.
Brake Caliper Painting Service UK, better than powder coating
Did they apologise and rectify the work? Be useful to know.
