Brake pad wear sensor
carribine
Have just replaced the brake pads on my 2003 C180 komp sports coupe and the brake pad wear warning still appeared. So have had to change the wear sensor aswell. So if your changing front pads on a W203 C class it might be worth getting a sensor as they are only £3.80 from euro car parts.
This is recommend standard practice. Good reminder though.
The sensors can be used only once, if the warning light comes on they have to be replaced, if the warning light has not come on, the sensors can be re-used.
