I recently upgrades from a 190e to a C 180 auto 65k 1997 with no EC
Last Friday bank holiday rush i was caught up in traffic jam (100 meters in about 1hr).
Just after a hour i hard a loud explosion and then steam all over the bonnet. The radiator had explodes and the antifreeze has spread all over the engine.
Prior to the explosion i did not hear the fun come on. I suspect the temperature went in to red with out me noticing.
The temperature would normally rise up quickly to over 40 in less than 5 min's and would settle at about 90.
I bought a new radiator and fitted it the following day. The temperate still rises as before. The engine oil level is ok and water level in ok.
In replacing the radiator i lost a small about of transmission oil. Are there any precautions i should have taken in the process of replacing the radiator. Was any bleeding of transmission oil necessary before tightening the pipes.
The car still drives well but there seems to be a delay in gear shift. May this have been cause by the loss of transmission oil.
Can the transmition oil level be checked easly ?
Does the fan have a fuse i can check before another explosion.
Any ideals , advice etc..
cheers
cheers
