I have just got a new motor and before i fit, is there anything i should do with the motor before i connect it to the wiper part, such as plugging into power and running it to set to home / park.
Yes Mark, park the motor, as follows;
= plug in the new motor… don’t connect it to the mechanism yet.
= turn on the wiper switch to normal speed for a few seconds, motor will run.
= turn the wiper off AT THE STALK SWITCH.
= Wait a few seconds for the wiper motor to finish its cycle and come to a stop.
= remove keys from ignition, motor is now parked.
= fit new motor to mechanism via 3 bolts.
= connect nut 2 and tighten it up, make sure the V mark is in line with the short motor arm.
= adjust nut 1, if necessary, so as the alignment marks are lined up as in first picture above.
= the rear of the mechanism should now look like the first picture above, refit and test.
Lubricate the mechanism twice per year…
YouTube - Maintenance viper on a Mercedes R129
Dec
