cplnoonoo
How did the remote connections with the 2 wires connect to the cars harness? and what was the power split needed for that you connected to the interface?
the closest I can find to show you is in this image, it is the thin metal surrounding of the unit show in the iage in the link, it is a think metal chassis that you put into the fascia and the 'tag' like bits are bent around the back of the fascia to keep it in place. This comes with the Kenwood (and indeed all head units, to me knowledge)
Apart from the fascia, you do not need any other bits (well, you will need an antenna adaptor as i mentioned earlier in the thread)
Hope this helps.
http://akamaipix.crutchfield.com/products/2008/130/h130P7000BT-B_dg.jpeg
So i got an answer back from kenwood the other day...they are going to supply me one of the last models available from the old range. The same one you used...MB1110. I have received it and have fitted it but buttons dont seem to work. the 10 way iso block on the car harness has 5 wires going into it whereas your one in the pic only has 2. The interface only has 2 so yours matches up fine but i dont know why mines has 5. What could the other 3 wires be for? I dont have a car kit installed but im assuming the prewiring doesnt include the extra wires on the stereo harness. Am i right? Not sure what to do next. Could i maybe have another 10 way iso plug hanging about behind the dash somewhere and this plug iv found with 5 wires is for something else?
I had similar install when i had a W203 52 plate a few years ago, thought i would suggest something to you though that i did. If you remove the parrot module and take the back off you can drill a hole in the back of it and re route the cable that comes out the bottom of it so it goes straight out the back of it. Then drill hole in the face of the blanking plate over the lower din slot and feed it through the hole and stick parrot module back on again. This would stop the cable from going through the gap at the bottom and look much neater imho, just a thought
Brilliant job on this thread Omega1, to say it's invaluable is an understatement, so i'd really appreciate your advice (and everyone elses).
I'm buying a 2002 (March) C270 from my sis (family loyalty = really great price) and the 1st thing I intend doing is replacing the Audio10 excuse for a stereo with something a bit more suitable, so i'm thinking of a double din Kenwood DPX503U Kenwood DPX503U
with the Kenwood CAWMB1110 OEM remote control interface Kenwood CAW-MB1110
So couple of questions
1. Will a double din stereo fit the 2002 c270 with the correct fascia adaptor of course?
and
2. does the can-bus iso plug just plug into the CAWMB1110 OEM remote control interface and then the interface just in to the stereo?
Are those the only connections required ie no additional permanent 12v or anything weird!!!
This is my 1st post and 1st MB so please be gentle!!!!!!!!
Richard
Thanks cplnoonoo, i'm going to try and source a CAW-MB1110, if I can't get one i'll still do the install and just wait to Kenwood get their act together and make something that works or re-introduce the CAW-MB1110. So you haven't put me off lol, but ain't no way i'm starting to mess about with the electrics of a MB.
Do you know who makes the fascia adaptor you recommend?
Richard
