c250td chugging at idle
Uberderv
C250Td
Hi all,
When the car is at idle and I put my foot on the brakes the engine really seems to struggle, would this indicate a vacuum problem?
Thanks in advance, Pete.
If this is happening in gear, I'd have a guess at something in the gearbox or torque converter.
If is just vibrating and shaking the car, then i'd check your engine and gearbox mounts.
Chugging is usually a n injector seal that has gone - this would affect the fuelling map in the ECU.
Take the engine covers off and check the head for black carbon build up.
its probably the common air in the fuel pipes issue.... hard to tell with vague description of the problem.
check your clear fuel pipes - do you see any bubbles when the car is idling?
I did have a problem with air in the pipes but after changing the orings its much better.
I happens when the engine idles in neutral, runs nice and smooth until you put your foot on the brake and it starts to chug like it wants to stall.
That sounds like a torque converter fault.
hmmm i've had this with cars in the past, where you come to a stop and the revs drop really low and then rise back up..... could it be alternator/voltage related????
At idle in neutral the revs drop by 1-200rpm when I press the brakes which makes the engine chug, could it be a pump fault as I seem to get problem after problem with this bloody car.
Thanks Pete.
Check the engine earth strap and the alternator +ve connections. It could be the voltage is dropping when the brakes are applied, so causing poor running somehow.
that was my immediate thoughts also
Thanks for the ideas chaps.
