philnewmerc
Yep. I will phone someone and just say I want it changed instead of asking for advice (I was being polite, I don't want to appear arrogant but I suppose that's the way it has to be
It gets up to temp (about 80) driving slowly or just left to tickover - cools down at speed (i.e. constant speed on the motorway) to 59-64 roughly, according to iCarsoft
How much were you charged for these words of wisdom if you don’t mind sharing?Diagnostics back from Merc dealer technician regarding my thermostat:
"There are no errors and the sensors and wiring are fine."
And what about the fact it runs cool on the motorway? I left a picture from the data logged in the code reader showing the water and oil at 60 deg or so.
"I can't go off that as it's not our readings. I drove around town and it was up to temp"
FFS
"And our health check says you need all new tyres and brakes"
Get away!?
At end of tether now. Is this proof we're living in a simulation matrix and this is the rather obscure glitch?![]()
For some reason I can't quote OneForTheRoad's post #46, but if it were not for the fact that one mounting bolt in the thermostat housing is impossible to remove without removing the long shiny alloy pipe next to it, which in turn requires a couple of seals to be replaced as well, replacing the 'stat would be a quick d-i-y job.
£1250? How much do they charge for brake pads, £200 a corner? I assume you won't go back to that dealer...
Mother of God !!…..£1250 ??Tbf I didn't think it was too bad (noting that they said the same as every other mb specialist and considering I got a courtesy car and could drop off early and collect late, so convenient for work), it was about 200 for diagnostics (also asked them to check something else in addition) and 370 for a full gearbox service (decided to get that done for piece of mind at same time).
They quoted 1250 to do the thermostat but with no guarantee it would have the desired effect on engine temp (don't ask me).
So late yesterday I phoned a Halfords Auto Centre which seems to have good Google feedback and, instead of my usual non-patronising way of explaining the symptoms and hoping the chap would say you need a thermostat instead of 'that sounds fine mate', i said "my thermostat needs replacing how much is that?" He quoted 480. So it's booked for 28th. Only now am slightly concerned about a non-specialist chain garage working on it. Is it straight forward compared to other makes?
Thanks for all the replies, very much appreciated as I was beginning to doubt my own judgement .
I hope the mpg improves afterwards otherwise my '4 cylinders or less belongs in a motorbike ' opinion will be forced to change![]()
Just checked online is this your stat ?..£156 MB dealer
And still save the op £100I'll pick you up buddy , £500 each we'll do it..
300 sounds an absolute bargain. Are they anywhere in Hampshire by any chance?Had my cars thermostat changed last year by local Merc truck dealer
Steady 90° showing now at all times, mpg at 40.6 over 7000 miles, up to 47 mpg on a run
Best £300 I have spent on the car
£1250 good god . I'm in the wrong trade .
Your mpg will drop significantly,as the car is running on colder maf calculations not Hot ones
Watch the German butcher at work herehe changed his in under 23 minutes.
If yours looks like this , it's even easier.
For some reason I can't quote OneForTheRoad's post #46, but if it were not for the fact that one mounting bolt in the thermostat housing is impossible to remove without removing the long shiny alloy pipe next to it, which in turn requires a couple of seals to be replaced as well, replacing the 'stat would be a quick d-i-y job. You don't even have to drain the coolant if the car can be parked facing up a slight slope, or with the front wheels on ramps.
More!
B service is 1200 quid with fuel filter and air filter
See screenshots![]()
For every person who says 1 hour there'll be another who took 3 weekends due to a snapped bolt/other calamityMother of God !!…..£1250 ??
It’s a £100+ part , with an hours Labour ?
I’ve got the earlier om642 , 2 years ago I paid £34 for a Wahler stat from AUTODOC ,I know your stat is more expensive. It took an hour and that was the first time I had done it .
. Seriously find yourself a mercedes independent and keep away from a main dealer.
