Chint Europe (UK) Ltd - Product
If you have something similar to the above, it will trip both switches for an Earth Leak, or one switch for an overload. I work with various powered systems and know of the surge issues associated with startup. If you can isolate whether it is a surge or an Earth Leak, then you can determine the course of action.
As someone said, upping the rating of the device from a 'B' to a 'C' would certainly overcome the initial surge issue, but if the issue is with Earth Leakage, you may need to put the vehicle charger on its own dedicated final circuit. I should point out that many electrical items, including chargers, will leak small amounts of current to Earth, and if you have too many of these minuscule leakers on the same final circuit, it can trip an RCCB. Computer power supplies are notorious for Earth Leakage. One test you could try is to isolate all other circuits in the home except the car charger circuit, and see if it still trips the RCCB when you power up. If it doesn't, switch off the charger, reconnect all your other circuits, then try again. If it does trip, you probably have a cumulative Earth Leak from all final circuits protected by the RCCB.
If I was installing a charging port for a vehicle, I would have given it a dedicated final circuit protected by its own RCCB, taken from the main isolator. It sounds like the charging circuits share the RCCB of the existing installation. Also, charging circuits vary from manufacturer to manufacturer. Many of the systems I use gradually increase the voltage supplied to the battery packs instead of an initial surge, as a protective mechanism. Mind you, I recently sent three Iota chargers for repair because they had an Earth Leak, only for them to be returned with no problem found. I can only assume that the Earth Leak was caused by moisture, and rectified itself by being left in an ambient environment.
A little known trick. If you suspect contacts are getting moist or wet, and are causing an Earth Leak or short, use some silicone sealant to seal the contacts. This stuff does not conduct electricity, as proven by my Fluke Insulation Tester. This is ideal for junction boxes that are prone to moisture or flooding.
