Looks the same as mine (Feb 2016 build)
If we presume the latest C350e [feb 2016 build ] would in fact contain the modified charging socket/cable [ possibly one of the reasons owners of older models may have to wait for the necessary modification parts--- new production cars will have "first dibs" in a limited supply situation??] then this would indicate the changes are not immediately visible. I did notice on the parts diagram that there appears to some sort of grommet/plate assembly about half way down the cables pass through- perhaps that's what's been modified?
I've just heard from my dealer to say that my vehicle needs a new battery which is going to be a back order item.
Will discuss with them when I pick it up later that the battery is working perfectly and charges when driving etc normally.
It's external charging that is the issue.
Suspect they haven't sold many hybrids![]()
They are pretty confident the battery is the issue and the replacement will arrive Tuesday at a cost of £1,300 obviously covered by warrantee.
Thought a HV battery would cost more but assume that is the internal MB price.
Car still charges via CHARGE and works as normal excepting external charge doesn't work.
Glad I chose Brilliant Blue as they've cleaned it and it looks stunning in the twilight.
So, vehicle back in on Wednesday and apparently battery can be changed same day.
