Justin1600
- Dec 28, 2010
- C43 AMG
Just go easy, bud!
Agreed, don't jump in with two feet e320cdiowner. Take it a step at a time.
Don't want you to end up in the scenary
Just go easy, bud!
Good to hear from you Andy! Hope you are doing ok?
yep ...im definitely driving like a lady !
I still haven't had the balls yet though to switching that TC off on it yet though.
Come on chaps....at least use the sport mode and try balancing it on that.
Get it just enough sideways but not too much for the electronics to get involved...you'd be amazed how much more fun roundabouts can be and all in relative safety as if you do happen to sneeze and smash the gas into the floor, the safety net is still there!
Hi Palmball
I do use sport mode(on the g/box) and particularly like causing frantic rev matching under heavy braking
oh and with full ESP On its been possible to get the back to step out slightly albeit it steps back in very quickly
-but even my wife is partial to sport mode!she says its a bit livelier
I didn't know even how to switch off the ESP totally until reading this. Shows you my ignorance. So you hold the ESP button in....Guess what I'm going to be doing tomorrow he he he.....
So how you getting on with the Porsche mate, still loving it? One of the guys at work just bought one and absolutely loves it.
I went with one as much as being a safety feature...As Palmball says it is an additional £1500 as an option on the 2010 models and didn't come with the PPP.
Hi see sixty
why are you changing the M3 ?
Thanks for all the pointers guys! I knew Palmball would have something to say on this
There seems to be a bit of confusion between Sport Mode on the gearbox and Sport Mode on the ESP system.
Sport Mode on the gearbox increases gearshift speeds, increases throttle response (I think), holds revs longer in each gears and changes down quicker under breaking. It has NO effect on the Traction Control System.
The other Sport Mode is on the ESP system.
The ESP button is in the centre of the dash, above the centre console. It has a warning triangle on it.
This ESP button has 3 settings.
Normal: This is default mode and every time you start the car it starts in this mode. The Electronic Stability Program (ESP) thresholds are set very low. Even the slightest amount of slip generated at the front wheels or rear wheels will trigger the ESP system and use a combination of cutting engine power and breaking individual wheels to reign in any slip. It is a very intrusive system and is actually working even when the little warning triagle on the dash isn't flashing.
ESP Sport: To enter this mode you press the ESP button once. You will get a warning triangle illuminated on the dash permenantly. You will also get a message on the centre binnacle to tell you that you just switched ESP into Sport Mode.
The result is that the car will now slide to much larger slip angles before the ESP will intervene and break wheels or cut power to control the skid. This is a great halfway house for those that want to feel the rear of the C63 move around more. It will allow quite big and smooth skidsd on roundabouts, but still cut in to sort it out if you overcook it.
ESP Off: Push and hold the ESP button for 10 seconds. This turns ALL ESP control OFF. The car is now 100% in your control. There is no intervention from ESP at all in any situation.
Unless you are very very used driving a very powerful rear drive car with no electronic aids at all I would not recommend the use of this on the road. It is OK for use in a large empty carpark to learn the limits of your car, but on the road there is the potential to end up pointing in the wrong direction, or in a hedge or someones front garden before you can even say "ESP"!
I hope that clears up a bit of the confusion.
Questions?
Questions?
Hi yes 100% get one with a lsd
P/pack comprises
COMPOSITE BRAKES
10% STIFFER SUSPENSION
LOCKING REAR DIFFERENTIAL
ALUMINIUM TRIM
LEATHER/ALCANTARA STEERING WHEEL
Have you seen this one ? looks good value
Mercedes : C63 amg 59 reg performance pack lsd command
