I have a spare bonnet if you are looking for one well actually I have 2
I'm sure you know this already but you'll need facelift headlights for this to fit
C63some said:Yeh yeh i know...iv emailed automotive gadgets with regards to their facelift headlights, but they arent exactly very forthcoming with information. Its rather frustrating!!! Cheers
As far as i can decipher from automotive gadgets website, these should (should) work however i do think i will need an adaptor at the headlights with a branch off running to the DRL's. i assume i will need to go to mercedes to disable the coding to the fog lights due to them being removed. Hoping the DRL's will work im the same way as a facelift does.
If the website is anything to go buy, i am hopin all i will require is an adaptor and the headlights should work, and then will look into whether the DRL's actually work!
C63some said:Cheers AMGeed, yeh iv been yapping to Lee about it. The only real difference is he went OEM headlights. I plan on going aftermarket. Tell me Ash, the preFL and FL actual headlight plug, they are physically the same yeh? Just different number of pins. My prefacelift has washers already, so obviously i will be using the covers from the new bumper, but i am guessing, the connection is the same and will work exactly same as pre facelift
