Wrong choice but enjoy it.M156 vs M177 ... I always wanted the 6.2, but when I had the chance to get one, I went in a different direction. I think I watched too many videos on cam shaft lifter nodes degrading and incorrect cylinder head bolts etc
From what I can see, the M177 appears an extremely reliable engine with very few inherent issues, if any. I'm only going through what I've seen on forums.
I'm just going through the process of purchasing a M177 C63. I'm going to be doing 15k miles a year, so I need more modern tech to utilise on a daily basis.
The interior of the W204 just isn't what I personally want from a daily driver.
This is very likely to be my one and only AMG V8. I'd have been happy owning either, but the 6.2 just isn't the right choice for me in 2024.
Take a look at the vacuum check valve fitted to the vacuum pump on the back of the left hand cylinder head. The valve fails and affects the vacuum system holding a negative pressure. Leads to delay in pick up.I get that completely, but i also think the 157 as implemented in my e63s has a rather annoying throttle response delay which probably has nothing to do with turbo lag from what i can tell but it's very apparent nonetheless. Perhaps the prefacelift 157 throttle response was different. So while that engine is special once the pedal you've pushed down decides to send the laggy message to the engine to wind up, ofcourse once it does you've got over 800nm of torque at work which is Well beyond the 156's NA talents. On the w211 e63 I had , the throttle response was immediate in sport mode (it was only let down by the transmission lag) , and certainly my recent v8 NA bmw (with only 330hp felt much faster at low speeds) and e93 M3 respond straight away as soon as you touch the pedal. My c63s was also very impressive in that regard when not in comfort mode. So in summary any mighty torque advantages it has are largely negated by the annoying lag. The 157 is a top engine but it does have an achilles heel. I've had mine 3 years and it's great but it's just a bit too damn slow to respond to be the perfect engine, it's damn close but not quite there. Maybe newer models that feature that engine have been set up differently.
Thanks mate, that's very useful and I'll get someone to have a look at that just in case.Take a look at the vacuum check valve fitted to the vacuum pump on the back of the left hand cylinder head. The valve fails and affects the vacuum system holding a negative pressure. Leads to delay in pick up.
On the one hand yes, and you add on to that improved AMG dynamics on their ESP on 177 cars and especially fsster transmissions, they're ahead for sure. However, I owned my w211 e63 at the same time as my c63s for around a year and to me the 156 was a more satisfying engine, with 630nm of torque , fully progressive with an unbeatable sound and experience as you rev to 7.2k, im sorry my 177 couldnt compete. Whereas most of my enjoyment from the c came from power sliding it and pushing on windy roads and it had better chassis , tranmission, dynamics and tech and thats all it does better, it doesnt have a better engine , certainly not on the C class version. Bottom line is there's w212 6.2l cars out there for 15k to 17k which is more car and value for money than the cheapest 177 s version cars which are 10k minimum more expensive last I looked a while back [edit : damn those c class prices have tanked ! I may need to reevaluate my view on this ! ]M177 all day everyday face the facts
It’s more powerful with a bigger power curve and drinks less fuel
Simple stage 1 remap puts you to 580 bhp and 900 nm
If you want to go mad stage 2 is closer to 630bhp and 950nm
Don’t need to ring the neck off it to get it moving
Nothing against M156 but time has moved on
Correct choice. Enjoy it.M156 vs M177 ... I always wanted the 6.2, but when I had the chance to get one, I went in a different direction. I think I watched too many videos on cam shaft lifter nodes degrading and incorrect cylinder head bolts etc
