C63 service cost
Jimmy2404
Derby
2011 C63 AMG with Performance Pack
Hi guys how much should I expect to pay for a service on my c63 it's done 27k and was done at 22k July 2013.
Also how much are rear brake pads fitted?
Also would a symbol/warning come up if I had low brake pad wear?
A standard yearly service "A" is roughly £260 (depending on area) but then you maybe due a gearbox oil change, a rear diff oil change, brake fluid change the list is endless.
What year is your C63?
3 yrs old then. Everything I've listed so be prepared to spend some money.
Pads fitted at Merc will be around £250 too!
All in all I wouldn't expect much change from £1,000. You can save money by supplying to oils that way you only pay for there service time.
Save even more with a good indie.
Tony.
Does the car have a pad wear sensor light on the dash, when they get super low? I only do say 20 miles a week. Sometimes I don't even go out in it
Jimmy2404 said:
Hi guys how much should I expect to pay for a service on my c63 it's done 27k and was done at 22k July 2013. Also how much are rear brake pads fitted?
Enter your details here for a quotation, supplying your own oil provides a worthwhile cost saving.
https://www.mymercedesservice.co.uk/home
