Can comand be retrofitted into a 190E
Robby
Edenbridge, Kent
Smart Roadster
I'm sure this was mentioned or attempted by V12 a while ago. Does anyone know if a dinosaur like the 190 can take comand at all, and how much work would be needed to fit it?
I think it can! as im dead sure ive seen photos of one fitted in a 190
EDIT: yeh thought so!Good old steve :rock:
LINK
It can, and it works great. My car is the one with the tan interior and burlwood surrounds... You need an ML-Comand (Non Can-Bus) though, or a modified Can-Bus Comand though - otherwise it will keep switching off every 30minutes due to a lacking Can-Bus signal ;)
I did fit command, from an early W208, but before i even got the car back on the road i was unhappy with the lack of inputs/outputs, so have changed over to a pioneer system instead...
Ricky
