Castor arm bushes...
Carrsey
Between a rock and a hard place.
E280 CDi Avantgarde
Popped into MB this morning for a little job and they did their normal check over and said i need "castor arm bushes". Had a look on EuroCarParts and ebay and cant find anything. Do these go by another name or are they a MB purchase only..
Its the aluminuim arm that holds the castor bushes.
You can get the bushes from MB or the whole arm from Euro. Only buy Lemforder.
Cheers mate can you just confirm from the links in post 1 if its the upper or lower arm that is the castor.
Lower is steel with the thread pointing up, upper is aluminium with thread pointing down, replace the arm complete, if you do the bushes and the ball joint fails at a later date you will wish you had done the complete arm.
