Bellow
Hardcore MB Enthusiast
I was thinking about efficiency
1 compress
spark
2 push
3 exhaust
4 input
You must lose some (power) efficiency with a turbo because the pressure at the end of 2 should be higher than in a NA engine, yes?
There is greater back pressure that the piston has to work against, but conversely the intake stroke is easier as the air is essentially pumped in creating positive pressure on the pistons (pneumatic transmission) derived from energy that was otherwise going to waste but is expanded through the turbine of the turbo and its energy extracted. Thus the expansion ratio is increased which is what we really are referring to when we talk of compression ratio, the efficiency of an engine being fundamentally linked to that parameter.
For road use, turbos allow for greater efficiency at the same power output as they are made smaller incurring less losses to friction and heat loss. There are limits though - the OEMs are complaining that the reduced compression ratio required to prevent detonation under boost conditions is hurting part load economy..
right ok so what we are sayig is that what ever it is filled with be it air/fuel the more it can hold the more it can combust resulting in more power?
But to make the maximum power, the mixture ratio has to be within a narrow band so knowing the quantity of one, you could deduce the other! Best though to think of the engine as an air pump as it is in the movement of the air that all the work is done. Adding a squirt of fuel is a doddle by comparison.
For anyone who really wants to understand how all the factors play out, have a look at the Ricardo book - The High Speed Internal-Combustion Engine. He lays it all out based on all the research he did in the last century. After the Ladybird book, it's number 2 on the reading list!
