Hi there,
My C220 CDi (2001) has been behaving strangely lately. Let me share few things. Basically it got down to limp home mode kicking in randomly and the error on Star Diagnostics saying its something to do with the intake manifold motor. I have not sent it to MB yet and did the diagnose at a local mechanic. And the other i think related problem is that the engine would not start as normal, esp in the mornings. Nowadays i need to press on the accelerator on start-up for 5-10 secs, if i rely on its own, then the engine will die off within 2-3 secs. If this occurs, the engine will not start for quite a while, maybe after 5-10 mins or so, even then i have to ensure that i step on the the 'gas' pedal briefly....
What the local garage has done so far is not replace anything yet, but apparently clean the intake manifold area (flaps??) and also the fuel pump. He also bled the fuel line to rid of air bubbles. After this cleaning, the engine seems to start better, but after 1-2 weeks the problem comes in again. The bizzare thing is that the car will start run normally once on the go, in fact i whacked it at ridicolous speeds at times and all seem ok (hoping to get the pump, etc working hard)...then the next morning, the starting problem comes again. It looks like the cleaning does have an effect, but only good as a temporary measure.
Do you guys think its a fuel pump or some fuel delivery system related issue here, what about the inlet motor?? The car has 185000km on its clock and more than 5 years old already. Any clues greatly appreciated.
Cheers..
Cheers..
