Changed seats on my w204
bath1960
Changed my cloth seat for half leather, seats are the same but I am getting a warning malfunction left right seat go to workshop does have any ideas
Sorry i don't have an answe to your question, but I am wondering who changed your seats for you? I have half leathers at the moment, but might consider going for full leathers now. Was it expensive to change the seats?
Occupancy sensors not connected ???
hi,there was two connectors under the seat a yellow block and a small black connector both are in place
sr100 said:
Hi, Sorry i don't have an answe to your question, but I am wondering who changed your seats for you? I have half leathers at the moment, but might consider going for full leathers now. Was it expensive to change the seats?
I changed seats myself, it was quite easy,only problem is this warning on dash!
If the ignition switch was turned-on at any point while the electrical connectors at the base of the seat were disconnected, then you will get an SRS fault message on the instrument cluster - is this what you are seeing? If so then it will need clearing with STAR computer (or other SRS reset tool).
Otherwise, the seats you fitted might not be the same as the ones removed (e.g. half-electric, full-electric, memory seats etc) in which case you will need STAR computer to tell the car that it now has different seats.
markjay said:
If the ignition switch was turned-on at any point while the electrical connectors at the base of the seat were disconnected, then you will get an SRS fault message on the instrument cluster - is this what you are seeing? If so then it will need clearing with STAR computer (or other SRS reset tool). Otherwise, the seats you fitted might not be the same as the ones removed (e.g. half-electric, full-electric, memory seats etc) in which case you will need STAR computer to tell the car that it now has different seats.
thank you
