Ian B Walker
- Jun 7, 2003
- Location
- Freckleton
- 300-24, saloon and coupe, E300 24 valve diesel estate
The air con issue is that you have to unbolt the Condenser from the Radiator as they are attached to each other. This can sometimes be tricky. I have found that it is easier to remove the front bumper rather than disconnect the air con system. By doing this you can get at the bottom bolts that hold the two items together.
