I would recommend getting an aircon specialist to do this for you! If they recharge the system and put some dye in at the same time you're looking at a bill between £50 and £100 though .PJutla said:Is there any tools out there that'll let me diagnose a air con leak on my SL500, i was thinking about using a uv dye, is there anywhere i can buy this stuff from to do this myself?
The guy who recharged my aircon said that the vacuum system he used to remove the existing gases is also able to tell if there is a leak, it didn't find any in my car, which doesn't explain why the gas he put in vanished after only a month!Steve_Perry said:As the others have posted your best bet is to take your car to an a/c specialist. In addition to the UV dye route for leak tracing, they will also have an 'electronic sniffer' that changes buzz pitch the closer it gets to an a/c system leak. I'm guessing you have a hole in your condenser somewhere as these are typically the first to fail in an a/c system.
When GF looked at mine, he used a handheld electronic device that made a buzzing sound which changed pitch depending on refrigerant concentration. In the end we didn't need it as we could visibly see my condenser spewing gasShude said:The guy who recharged my aircon said that the vacuum system he used to remove the existing gases is also able to tell if there is a leak, it didn't find any in my car, which doesn't explain why the gas he put in vanished after only a month!
PJutla said:Hi guys
Prit
