Well I plugged in the computer over the weekend... my friend gave me his Carsoft v7.4 program to play with my car for a week or so...
Now I have ordered a new MAF sensor, as it indicates this is the major problem apparently. I have read live data for the O2 sensors the front ones play from 0 to 1V all the time... and the rear ones seem more solid around to 0.465V so as I was told they do seem to be in good shape.
The program when I diagnosed the ME gave me the following error codes... in case you can make sense out of them more than I do.
P2050 Misfire (KAT Harmful (P0300))
P2051 Misfire at Cylinder 1 (KAT Harmful (P0301))
P2053 Misfire at Cylinder 3 (KAT Harmful (P0303))
P2056 Misfire at Cylinder 4, 5 or 6 (KAT Harmful (P0306))
P2004 Hot Film Air Mass Volume flow sensor (P0100)
all these above are classed as stored errors and as actual errors.
Now moving along ... some more errors I found :
EGS Diagnosis .. (what ever that is)
148 Selector Level blocked / Converter lockup clutch (KaB)
Airco Diagnosis
B1000 Module Defective.
PSE Diagnosis
It did not give me any more details on those?? I do not know what PSE is nor the codes.
B1443
B1444
Airmatic/ABC Diagnosis
C1525-001 Critical Vehicle Level : Front Left Side.
(I think this came into action when I parked one of the car wheels on a speed bump, and it was only me in the car... switched off ... and then I had full luggage and 5 people in the car the next time it switched on ... it came up straight away ABC too low red in dashboard... it gone away as soon as i raised it from the dashboard one level.) But it recorded it.
OCP Diagnosis
B1879 SHD engine (el. roof)
B1881 SHD is not normal.
UCP Diagnosis
(I think some of this might have to do that the airbag module is removed?... in process of replacing it)
B1088 CAN communication KI module.
B1559 AB Child seat light activation signal
DCM Diagnosis
(I have no clue what this is??)
B1521 Mirror glass positioning faulty.
Any help would be appeciated guys...
thank you in advance.
