KARIM1
- Apr 28, 2010
- Location
- London
- w209 CLK 320 CDI Sport - W209 CLK 240 Cobertible Avantgadre
Hi All,
long time no post (no issues hence no posting)
So for a while now my steering has been getting slightly bad, i.e itl tramline now and then and when going over speed bumps the pasenger side dips that litle more then the driver side (also sometimes a litle clunk) the rear wheel on the same side will bounce when doing a litkle wheelspin on take off (i think this is due to a large speed bump getting hit a litle too fast on that side ) overall the steering isnt as sharp as it used to be i recemntly had it aligned, and it was "better tramline wise for a few months but is getting worse and worse and its about time i dealt with it properly.
so i have done a litle research and think the front shocks are gone/going (its just hit 60k miles) and maybe the drop links and sway bar bushes. as well as the rear shock on the same side
i have purchased the bilstein pro kit for my car, im considering the eibach anti roll bar kit, but may just continue with the standard and have the bushes chan ged out i hope all this sounds like im going in the correct direction?
regarding the antiroll bar for the CLK 209, does anyone know if the rear is easy to fit? iv read on some mercs you neeed to drop the rear sub chassis ?!?
so after doing my home work im stuck at 1 point, the spring pads, i have read the 209 only has them on the rear, after this i cant find any info on what would be the standard one for my car (it is the sports) ? has anyone got any knowledge of the correct sizes for each version of the CLk or has changed theirs and knows which were there/used ?
thanks for any help at all.
