Can anyone tell me out to remove the outer windscreen trim panel that runs along the edge of he front windscreen from the wing to the roof? Is it held on by clips that need to be replaced? If so does anyone know the part number? Thanks
Dont pull it!! There is a hidden screw - from memory it is along the edge where the rubber meets the windscreen nearer the bottom of the trim, just pull the rubber part back and feel with your fingertips along the edge and you should find a cross head screw. Undo this and then the trim will come off with a slight tug - there are some square fixings and a couple of round clips at the top. If your getting these direct from Merc they will have the exploded diagrams that will show the parts and all come to less than a tenner. Hope that helps
