They won't work unless you change the cluster wiring, you can't just use ones with built in resistors.
Estmated cost 1k.
The xenons alone will cost you £400 and then you have to either take it to MB dealer (£60ph min) to have it coded to accept the xenons or have your (my) amazing mechanic contact Autologic to write the code for you.
The after market LED rear lights need the facelift bulb plates and loads of resitors. Looks like a ball ache to mess around with as was fitting the facelift rear lights was on mine.
Hi guys,
Just received the LED tailights and they are a Joy and easy to fit. I spent about an hour most. I Also changed the grille or an updated look. I will be opening a separate thread soon.!
Those LED lights look ridiculous.
Sell them to me for a fiver and I will dispose of them in an environmentally safe way.
I bought a set of them 3 years ago I think from the same seller, fitted in 15 mins each side, came with a pair of black plastic square electronics box for each unit that connects into the wire loom connectors for the tail lights, never had a problem with them, look so much better on the car, they also came with a pair of reflectors to stick on the rear of the car as the light units don't have built in reflectors which are a legal requirement, the car still seems to pass the MOT with out them.
I also put these LED DRL's at the front keeping fog lights.
