SD card prevents satellites from being seen
Hi, when I use either a 2Gb or a 4Gb sd card (not sdhc) the mp3's work perfectly, BUT the navigation stops seeing the satellites when the card is inserted, so the navigation won't work whilst the card is in. As soon as the card is removed the satellites can be seen again.
When Richard coded my unit, he said he had seen the problem before, and suggested I try a 'Sandisk 2Gb' card, but after buying one I still have the problem. I assume I have an upto date firmware (as Ricahrd coded it last month) and there are only MP3's on the card, and I have been able to copy the music to the hard drive.
Do people think it is the type of memory card causing the issue, or might a subsequent firmware update cure this...thanks!
p.s I will try an sdhc card this evening to see if that works.
Harvey
Harvey
