amwebby
This is for COMAND APS isn't it? I've I tried it on 2.5 and it didn't work anyway.
What I posted was for comand 2 and Comand 2.5 alledgedly.
What I posted was for comand 2 and Comand 2.5 allegedly.
Which COMAND do you have? What menu do you get? Pics please.
Just tried it on my COMAND - comes up with the menu, etc, but nothings seems to change.
I assume it's like the rest of COMAND - scroll up and down the list and then press "OK", and the press the "Back" softkey to exit.
Unless the change is very, very subtle.....
. In the engineering section it states, Tuesday Nov 23 – 48/2004. Any ideas?
when in danger or in doubt, I always tend to 'opt out!'Hi Glojo, sorry to address you like this but I have read all your information about the command module, starting way back when. I am having a problem with mine, SLK 171, that MB deny is a problem saying they have updated it with the latest disk, it reads V 8 maps without a problem, but still allows access to the engineering menu, no ETA on screen nor does it show traffic jams on the correct side of the road, but it does play MP3 disks. In the engineering section it states, Tuesday Nov 23 – 48/2004. Any ideas?
With regard to my last post - if Alfie and Richard see this and have any ideas I will be gratefull, I will contact MB about the 'time warp' and ask why it is showing that date, but my impression is that they will not know, from one of the USA sites I got the impression that all the updates were not on all the disks and they all had to be entered, so they may well have used the latest to get the V8 working but it did not have all the upgrades/bug fixes. Any ideas on this?
Hi Alfie,Okay.
The headunit update is separate from the navigation drive update.
To go from some early versions of the navigation S/W to newer versions (up to V7) the navigation processor update was most likely required just to have the drive read the disk. With version 8 the necessary update was included on the disk so simply pop it in and it accepts it with it running a small update first.
To gain ETA and correct the traffic on the wrong side of the road issue, you need the headunit update. This will remove the engineering menu aswell.
The 48/2004 shows the week that your headunit was manufactured. November 23rd was a Tuesday in 2004 and is remarkably close to week 48 of 2004. You have a very early comand head unit.
Hope this helps,
