Maff
What was the part num of your COMAND (you can find it in one of those diagnostic menus) or take it out
Im trying to work out which COMAND units can be coded to read the speed signal and lights signal from the C2/A connectors
- The 210 540 54 89 doesnt seem to be able to
- Some CLK units seem to be
- The ML units can
Steve - I think you need to find the CAN bus stuff in your car and connect it to your "non CANbus" comand to make the lights work on it. The CAN bus "distributor" will be in one of the wiring ducts in the footwells (sill side), and you should be able to connect to it there. I will find out if it connects up to one of the old APS-4 connectors behind the head unit,but im pretty sure it doesnt.
Somewhere I have a "CAN" twisted pair cable from distributor to head unit - I will try and dig it out for you and send it - give me a couple of days ...
Cheers
R
- The ML units can
Cheers
R
