Haven't bought gaskets from ECP before but they should be ok. Worth checking the price of an MB set though, might not be as expensive as you think.
That kit is a complete set for a head gasket swap (HG + intake/exhaust manifold gaskets and seals for temp sensors etc), but it does not include the valve stem seals or cam cover gasket.
You can measure the head bolts to see if they need replacing, there is data on WIS that specifies the maximum stretch length.
Will
ECP sell the seals as well, £12 each, I'm assuming I'll need 8 of them?
Is there another name for the cam cover gasket? I seen a part 'Rocker cover gasket'
What about the piston rings, do they normally need changed?
Cheers for all the help!
