Computer recommendations please
Harrythedog
Tynemouth
GLC 250 Sport Premium+
As per the title my faithful old desktop is very slowly dying so needs replacing.
Can anyone recommend a good make for a desktop, looking for Inteli7, upto 16gb memory and windows 7.
Thanks in advance my learned friends
I think you will struggle to buy anything with Windows 7 on it now. You will either need to get something custom made by a small PC shop or you'll have to wipe the OS and 'downgrade' to windows 7.
My question would be what are you intending to do with this computer exactly? Is it a gaming computer or just for browsing/email/work? If purely work, are there any particularly hungry applications you depend on? Things like Autocad or Video editing for instance.
Any particular reason why you are thinking of an I7? Consider perhaps an i5 with a super quick solid state drive for the OS may provide most bang for buck.
Best place to start is intended use and budget and go from there.
To be used for work (accounting,Excel etc) and internet browsing.I tend not to change things often, I've had this desktop for about 7 or 8 years, so I want something that'll last
Whats your budget?
How much do you know about computers? Is buying separate components and putting them together out of the question? This would be by far the cheapest and most efficient option.
As mentioned by Spike, i7 seems a bit to much, especially this is for work and used for simple tasks.
You would only need to look at i7 for graphic rendering, running some sophisticated 3D (or similar software), or should you be a gaming maniac.
I have done a little spec configuration for you in the total of £600. The ready made system with similar spec, would set you a bit more.
Budget round about the £600 mark. Absolutely clueless with regards building one that's why I asked who are the decent makers. I've been looking on the Dell site but wanted others' opinions
To be fair, I think that all-in-one would be the option for you, given what you intend to use it for.
Have a look at amazon, there is quite a lot of choice there. Regarding the makes, I have used Dell, Asus and Lenovo, and these were all good systems.
Check this
http://www.amazon.co.uk/dp/B00BETCEFU/?tag=amazon0e9db-21
or this
http://www.amazon.co.uk/dp/B00ADHLESW/?tag=amazon0e9db-21
Dell are certainly still selling Windows 7 at the moment.
With the intended use of the machine, I would consider an i3 chipset as well as you aren't really going to be hammering it with those uses.
I would also not bother with more than 4GB / 8GB unless you intend to run a lot of stuff side by side.
Even entry level PCs are rapid these days so you can't really go wrong.
Ensure you buy a large enough hard disk for your needs and ensure you have provision for backing up your valuable data (memory stick etc.).
According to "which" they rate the Packard Bell oneTwo S Touch (1TB hard disk)
at around £436.00 June 2013 as a best buy in the "All in one" category
Given that you don't need super powerful CPU with loads of RAM for what you do its worth checking PC World for their end of line stock as they do sometimes have top spec machines at silly prices!
I've a potential problem as such in that the accounts program I use is 10 years old and SAGE have stated that it won't run on Win 7 or above. Now I got a mate to install it on Win7 and it seemed to run ok however as a backup he suggested (now bear with me as I'm not an expert ) a powerful setup so it can run WinXP in a virtual machine. To upgrade the Accs program is about £500 which I don't want to pay so I like the option he suggested as I'll need to check my archive records from time to time
You could do that - I think you have to buy Professional, Ultimate or Enterprise to run 'XP Mode'.
In all versions of Windows 7, you also have 'compatibility mode' where you can set the program you run to be run in an older emulated environment such as XP. Not as successful as XP mode but can work.
However, if it runs as is, try it. It might be just not 'supported' on 7 rather than doesn't run - which wont be an issue.
Alternatively, if you have the media for your accounting package and Windows, you could rebuild your existing computer a fresh and just install the accounts package as a backup.
Then, depending on how your experience goes running it on 7, you may or may not need to use it. If it proves too unreliable, either keep both machines on or maybe source a cheap laptop running XP (they'll be worth a lot less come 08/04/2014)?
I run a piece of software from early last decade as well as one from around 2005, both natively (i.e. not in any compatibility mode) without any issues on 7 Professional.
I seem to remember someone else on here in the same situation - would be interesting to find out what they did but I can't remember who it was - unless it was you asking previously...
Running old OS versions to keep obsolete applications on life support is a horrible idea and is just saving up problems for later. I'd bite the bullet and upgrade to an up-to-date accounting program. It doesn't have to cost £500 - there are plenty of decent packages for less
Sage One is £10 / month and you get phone support
Nick Froome
...4 years down the line you've spent £500 again.
Given how long the OP has been running Sage for and is clearly happy with it, what problems would occur later on by running it on an older computer or via an embedded emulator...?
It sounds very much like it will run on Windows 7 in any case so there is life in the old dog yet...
Normally applications will very quickly demonstrate that they will not work on Windows 7.
If they install, start and seem to be OK, chances are they will be. Of course you won't know for sure until it is tried - but at least you won't be forking out any unnecessary cash...
