coolant leaking as soon as I refill it
shizhab
My 1996 C200 is leaking coolant at the engine I refill it every 50km what could be the problem
Not clear from pic but yes water pump , the hoses or even the rad
Do you have antifreeze in the water you keep topping up or else you may burst a frost plug or hose or a weak point in the rad
When did you last change the water pump and stat and belt
This one has traveled 60 000km...The engine is now soo hot and the car doesn't have power anymore the rev counter can only reach a maximum of 4500revs, the max on the dashboard is 7000revs..also a croowww crwooo sound is coming out when the engine is on...
Don't run the engine again until you have changed the water pump, "soo hot" is too hot. If you're lucky you'll get away with just the cylinder head warping and the head gasket blowing. If you're unlucky the engine will seize.
:dk:
If you have run it until power has been lost you have certainly done more damage.
But by the time I parked it it could reach a speed of 120km/hr...Thanks very much the information was useful
Where are you located?
230K
Thanks very much I managed to get a new water pump and fixed the car it's as perfect as ever before...Keep up the good work
Thanks very much managed to get a new water pump and got the car fixed you were so helpful guys keep it up...
Thanks very much I managed to get a new water pump and got the car fixed you were so helpful guys keep it up...
I managed to get a new water pump and the problem has been solved thanks fir your contributions...
I managed to get a new water pump and the problem has been solved thanks for your contributions...
