Grahamcol
My C280 coolant temperature gauge seems to run very slightly hotter than I would expect now the weather's getting milder. In normal traffic it sits ever so slightly above the 80 degree (halfway) mark which I still consider normal. In stop start traffic it rises to just below the 100 degree mark (3/4 mark) at what I would estimate to be 95 degrees. Again, I'm not really concerned. However, by this time the electric fan has cut in but it often doesn't cut out again until the car hits a clear road again when normal ram effect of the cooler air brings the temperature down. Until the open road is reached the temperature gauge seems to indicate a more or less constant 95 degrees whereas I would expect the fan to bring the gauge down, cut out and then cut in again if and when the temperature rises. I might add that the car never overheats or goes over 95 degrees, it's just that I would expect the fan to cut in and out under stop/start situations but it often doesn't. Maybe it's a 2 stage fan and goes faster if the temperature rises further to a certain level (above that currently experienced) but I just don't know.
Is this all just normal. Anyone got any ideas please ?
