MecrazyBenz
Car: W202 98 Esprit 113K Probably all original suspension still
In recent travels my car suspension has felt it has been getting stiffer and noisier when going over speed bumps.
I jacked the front end of the car to have a quick look, and discovered a few things:
1) the front passenger side coil spring is cracked at the bottom. The Driver side appears to be ok.
Q. Are springs replaced in single/pairs/all four ?
2) when the streering wheel is straight, both front wheels have slight play when pushing on top and bottom of wheel/tyre.
Q. Does this sound like a bearing issue ? I do sometimes get a low humming sound when driving.
3) on full lock, there seems to be considerable play in the wheel when pushing it left to right. This play is about the same on the other wheel also.
Q. Is this common on w202's or should I be thinkning about replacing track rod ends or something else ??????
Also as im going to be replacing the coil spring/s, is it worth replacing anything else while my mechanics at it, such as dampers/bushes, bearing in mind the car has now covered 113k miles and probably still has all original suspension parts.
Thanks for any suggestions / help in advanced.
