Deep humming sound from rear of W202, normal??
240-singh
Hi guys. I posted a topic earlier regarding a humming sound i'm hearing and thinking it was something to do with the AC. But now im very sure its not the AC as i have had it off for the past day. Im hearing what can only be described as a fan which is turning on and off every now and again and its comming from the mid section/rear of the car. Its a pretty deep "hum" and lasts for about 2 minutes. probably occurs twice on a half hour journey. I would just like to know if this is normal or not as i dont want to cause more damage by keep driving it. Its a 1999 C240 sport.
Thanks.
sounds like fuel pump?
yeah it sounds like its comming from that area. but it sounds pretty loud for a fuel pump. could it need replacing?
Either replacing or the rubber mounts are past it. Also the braclet could be bent and rubbing on the cars underside. Have a look underneath and remove the plastic covering (right hand side).
Bracket......whoops:crazy:
Change the fuel filter first.....usually a clogged filter makes the pump overwork.
Thanks.
Wheel bearing?
Handbrake shoes??
Bazzle
