Hi Everyone, I'm just about (24 hours away) from buying a 2008 R230 and for the last two days I've been googling to try to find out exactly what I can and can't do with the batteries and there doesn't seem to be consensus. The issue is that I don't have a garage and the car will sometimes sit for weeks without being started. (Bad news I know). So if any one can help a newbie please:
- Does charging the rear battery also charge the front battery? Some people say you never need to charge the front battery, as it only starts the car, but others say it provides power to the convenience electrics if the rear battery gets low.
- Can I disconnect both batteries' earth cables with the result that I will have to reset windows when I reconnect, but that's all. I understand that spikes on reconnect might blow something.
- Does anyone have experience of connecting a solar panel to the rear battery? I do this on my C280 and S500 and it seems to offset the 1%/day charge loss of lead-acid batteries.
- I've got a CTEK charger so the plan would be to charge the battery(ies) fully before leaving the car. I'm hoping that at 30mA/day usage I'll get at least 30 days grace before the car alarm goes off. If this doesn't work I'm planning to use a second lead-acid full size battery in parallel with the installed battery to double the period I can leave the car without charging.
For interest my 1987 C280 reacts to being left for weeks with no problems at all. I just reconnect the earth and off we go. The 1992 S500 is more temperamental. On reconnecting the battery the pneumatic pump for the door locks clicks a few times and then expires. I'm wondering if the R230 will be equally temperamental.
All the best, Dave
All the best, Dave
