- Jan 10, 2019
- Location
- Cardiff / London
- 2x E350 CDI Sport W212s... for a bit
Hi all,
Recently did a lot of work on the car:
- Gearbox service & map
- New rear ARB drop links
- All front control arms (both sets) and ball joints replaced
- Front tie rod ends
- 4 wheel hunter alignment
- Brake fluid flush & MOT (no advisories) @ MB specialist/indie
- Fitted 17 Winter wheels
All Lemforder parts. No wheel balancing issues.
Problem: the front right wheel/disc does not spin freely when lifted off the ground - it ‘catches’ at a certain point, and then is easier to rotate for half the turn. Problem persists with 2x different wheels. I discovered today that the brake disc has a 'wobble' to it.
Real world side effects are subtle - very slight judder in the steering wheel at 65+mph and a very very quiet ‘whoosh’ of the sticky point as the wheel the wheel spins once per rotation at slow speeds. I don’t have judder when actually braking. Also for years, the car's brakes would 'jam' when the car's been wet and left for a long time and you'd need to accelerate hard to break it free, so I think this issue predates the work I've been doing.
The W212 had just sat for about 6+ weeks - please don't mind the rust on the discs, I moved it a little but ultimately it needs a good drive to clear the discs and pads. Today I discovered that:
1) The slider pins are really seized. I could hit them with a hammer and move them about but they both don't move freely.
2) I couldn't remove the actual pins/sliders inside the rubber boots so that I can re-lube them as I'm unsure how to get them out without destroying the rubber boots. No obvious cracks in the rubber. I will have to simply be more forceful. Hard to do when the caliper is hanging in mid air from a hook, though.
3) Spinning the brake disk with the caliper and pads removed, there is a bit of wobble on rotation of the disk. I've recorded a video showing this below. Is this an acceptable level or should it be completely 'true'? There is no play in the hub/bearings when I try to shake it from side to side.
My questions are:
1) Any tips on removing the seized slider pins?
2) Is the 'wobble' acceptable/normal and could the issue be caused solely by the seized slider pins? I assume not, I am thinking that there are two issues.
3) What do you think would be the most likely cause of this 'wobble'?
When swapping out the control arms, I removed the brake disk and hub from the strut. Could I perhaps have incorrectly torqued the two main bolts that hold the hub to the strut? I will double check this of course...
Any other thoughts would be welcome, thank you!
My questions are:
