flango
Hardcore MB Enthusiast
Hi Guys
Need some help and advice if anyone has come across this before, firstly it's a BMW engine
3.0 litre diesel in a E60 525 M sport. It has had the DPF removal by Eco-Tune Scotland see HERE It also has EGR delete. Recently upon accelaration and on overun there is massive amounts of blue smoke and I mean massive.
Problem is excessive oil getting into the exhaust, at first we thought it was the turbo exhaust seal as this is quite a common problem after a dpf delete and the turbo did sound a bit noisy, so removed the turbo and sent away for exam and report, report comes back turbo in good health a little wear but consistent witt mileage 100k anyway whilst it's off that is being refurbed. The turbo specialist reckons the cause of the problem is not the turbo exhaust seal but back pressure caused by something else, we have checked the usual suspects crankcase breather, turbo oil drain, have changed oils and filters regularly so it's not neglect. The dpf delete pipe is saturated with oil but we are sure it is not passing the turbo exhaust seal.
What we don't want to do is put the refurbed turbo back on and still have the same issue, whilst it is off we would like to find the root cause but are fast running out of ideas as what could be causing back pressure or is it something else?
Also anyone else used eco-tune Scotland and have any comments?
All help and advice welcome
TIA
TIA
