The applicable specification is BS EN 590:2009
There are two tests relating to cold flow properties or ‘waxing’:
• Cloud Point – the temperature at which wax crystals first form
• Cold Filter Plug Point (CFPP) – the temperature at which a standard fuel filter begins to block
The CFPP is the relevant one to consider. Specific additives are used to modify crystal growth to reduce the CFPP temperature.
EN 590 has 5 Climate-related requirements for cold flow properties (A to F) plus an additional 5 classes of ‘Arctic’ or extreme climate (0 to 4).
• Class A CFPP +5degC
• Class B CFPP 0degC
• Class C CFPP -5degC
• Class D CFPP -10degC
• Class F CFPP -15degC
Arctic grades:
• Class 0 CFPP -20degC
• Class 1 CFPP -26degC
• Class 2 CFPP -32degC
• Class 3 CFPP -38degC
• Class 4 CFPP -44degC
UK Winter Grade is Class F CFPP -15degC
Scandinavia, parts of Germany, Alpine France, Switzerland etc use one the Arctic classes depending on climate in the region – hence Bulla2000’s comment about -26degC (Class 1) in his region of Germany.
If you want a discourse on effects of a dirty fuel filter, why you should not add extra CFPP depression additives or petrol or kerosine, why some vehicles have problems when others don’t at the same temperature then just ask.
I used to manage oil refineries.
