The unit is CE approved.
The official kit is £635 mine cost nothing.
I have a fault with my Command in that it will not communicate with Star, this meant that I could not activate the AUX, also it will not go to sleep, but other than that it works very well so I have put a timer in that shuts it down ½ hour after turning off.
The digi box that I used is rare in that it has a RF modulator, so I have used this in one of the aerial sockets and has the advantage that as soon as I press TV the digi box comes up without having to select AUX.
Digi signals do not like amplifiers or the low impedance cables that are used in the car, they have the effect of attenuating the signals in the UHF band above CH 30, you can force them through with an amp, but as I said it is not good.
When the analogue is turned off I can direct the 4 inbuilt aerials to it, but no point at this stage as the draught shield works.
The fact is that i will probably never watch it, but as I could do it I have,, and it did not cost me one penny.
I am still trying to get the split for the aerial, not easy and not that important
If Mercedes built cars the way owners hack them, then I am certain the owners would never be owners.
B6 782 6422 = DVB-T kit (version A), Up to Vehicle ID No. A078550;
B6 782 6423 = DVB-T kit (version B), From Vehicle ID No. A078551 up to Vehicle ID No. A352880
B6 782 6424 = DVB-T kit (version C), From Vehicle ID No. A352881. From MY2003 (from 09/02)
the following small parts must also be ordered:-
four M5 nuts, N 913 023 005 002 (x 4)
four M6 nuts, N 913 023 006 001 (x4)
four M5 screws, N 000 000 001 703 (x 4)
B6 782 6455 = DVB-T tuner
Related:
B6 782 6426 = DVB-T connecting cable for CAN, Cinch
B6 782 6427 = DVB-T connecting cable for CAN, MQS
B6 782 6434 = DVB-T connecting cable for MOST
B6 782 6429 = DVB-T aerial adapter for Wiclick/Fakra
B6 782 6438 = DVB-T aerial adapter for Fakra/Fakra
B6 782 6428 = DVB-T aerial connecting cable for Wiclick/Fakra
B6 782 6435 = DVB-T aerial connecting cable for Fakra/Fakra
B6 782 6454 = DVB-T aerial housing set for Fakra/Fakra
B6 782 6449 = DVB-T operating instructions
B6 782 6446 = DVB-T remote control
(Richard do you mind adding this into your website ? Originally W220 data)
