Does anyone with a W210 need their rear subframe bushes doing?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
As above.
I have a new tool I need to try and I am not sure it will work. I will have the manafacturer of the tool present to observe it working or not as the case may be.
I will offer a discount if anyone can help.
Olly:thumb:
I would happilly give it a go if you were closer, but with 8 hours drive, its a wee long. Any news on opening a shop around Edinburgh :)
Not really. I need a 210 with worn bushes.
Black
If that is the Klan tool, and if it is similar to the tool for the 124 bushes, I can tell you that the tool will NOT normally pull the front two bushes (of the rear subframe) out cleanly.
It pulls the middle of the bush out, but leaves the outer still in the subframe, and you still have to chisel them out.
If that helps.
Pity that tool wasn't available when you did mine a couple of weeks ago Olly, I'd have gladly offered my 'help'. :)
