PJayUK
- Oct 6, 2008
- Location
- Surrey, United Kingdom
- ML320 W163, E320 W210 & Jaguar X300-XJR6
My W210 has developed a slight rumbling noise that is only noticeable at slow speeds (around 5 - 15mph). Its accompanied by some slight vibration that can be felt through the brake pedal but its not related to brake use, in other words it can be felt if I rest my foot on the pedal (without pressing it) at slow speeds.
I had the front wheels off last night and noticed that the offside one feels like its binding a bit when I span the disc. It certainly didn't rotate smoothly through one complete revolution. There is no discernible play laterally which made me think that perhaps its not a wheel bearing but a damaged disc or seized caliper.
The car is driving fine (apart from the slight issue mentioned above) brakes are efficient and stops in a straight line there is no wheel wobble but the drivers side wheel is slightly warmer to the touch after a run.
Not sure what the best course of action is really but I was thinking that re-greasing the bearings might help or perhaps replacing the discs.
Before I dive in or call a friendly indi has anyone got any offer any pointers, tips or views on what this might be and what I should do next?
As it happens, is there a howto that covers how to grease and adjust wheel bearings?
