MrGreedy
Nervously resurrecting this thread.
So I've still been thinking about this, and I want to test the rear heated screen as an option for taking the 12v feed for the DPF notification LED (if indeed the rear screen even activates during regen for the W212).
I was hoping to use my iCarsoft pro (along with a passenger on a very long journey about to be taken) to view a live data feed for exhaust temperature (it can do this, as can torque as mentioned above) and also have a look at rear window voltage to confirm rear screen activation. But I can't find rear window voltage in iCarsoft (nor incidentally anything around heated seat controls, although I could find those for my recently departed Insignia).
Can anyone offer any advice about where I could tap into the 12v rear heated screen feed?
I know fuse 49 (for the rear heated screen) from the rear SAM is an obvious location. It's 40A, so I'd put a small in-line fuse between location 49 and the feed to the LED, and then take an appropriate earth. I'm sure I can poke a tiny wire through from the boot somewhere and hide it in a discreet location visible in the rear view mirror.
