There is a light that activates on the switch itself (centre dash) when the rear screen is turned on via the switch.I thought there was a light on the dash, or on the switch, when the HRW is on?
Or have I completely missed the point?
Thanks.I respect the perseverance
You are to be complimented on your effort's MrGreedy. Well done.!!!. Very well documented and explained, step by step. And now it only remains to do a "Field Test" and hopefully, it will work. Good Luck with it !!!,Thanks.
To be honest, I would have rather only written this up IF it works. Not because I fear the incoming bout of additional forum ridicule; but because I nearly couldn't be bothered. At 1am. Having just finished.
The only tipping factor was that I knew for a fact I would have forgotten half of it if I'd left it a couple of weeks and it turns out it does work. And if it does turn out to be useful, I wanted to give back to the forum because I find the forum very useful and helpful and saves me a fortune!
Congratulations MrGreedy..... Success.Just got back from a good drive. Part way the blue LED I installed came on (no light on the rear heated screen button) and revs were idling at 800ish instead of the normal 600. I stopped only a few minutes after the regen had completed, and the tell-tale smell of a DPF regen was also present.
So, the rear heated screen IS activated during a DPF regen and the notification LED does work.
Brilliant, well done, well that’s my next job then.Just got back from a good drive. Part way the blue LED I installed came on (no light on the rear heated screen button) and revs were idling at 800ish instead of the normal 600. I stopped only a few minutes after the regen had completed, and the tell-tale smell of a DPF regen was also present.
Incidently, whats the tell tale smell of DPF regen? I dont think I have ever noticed any different exhaust gas smells before and I am fairly tuned into strange smells from the car.
