Driver's door rubber window strip 124 Est.
ssk
Can someone tell me how to replace the rubber window strip which fits in the door at the bottom of the window on the outside ? The present strip keeps popping up. Has a clip rusted ? Can I fit a replacement myself. Any advice would be most welcome.
literally just pull it up with the window down. You may need to remove the door trim if you cant get at it. Then get the new rubber seal and clips from the delaer, really not v expensive...
Jay
