Driveway Widening Letter
Whitey
Surbiton, Surrey
Seat Arosa 1.4 Auto :-(
Hi guys
Just had a letter from the council regarding getting my drive widened, but I'm having trouble deciphering the following :
"to prevent overrunning and damage to the footway the width of the new or widened crossover cannot be less than the width of the back of footway entrance onto your property"
Any comments ?
I initially thought that meant that my front wall cannot be cut back wider than the crossing, but then I thought that some people don't even have a wall ?!
Cheers
Whitey
w124nut
Somerset
Mercedes W124 E320 cabriolet
I would read that, " that the width of the proposed crossover (i.e from your drive to the road), must be equal to or greater than the width of the opening to your property entrance.
If it were less than, there may be a risk of you driving from your property with the wheels of your car running over the pavement.
If I were you, I would phone the local council engineers' office to seek clarification.
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
I think they mean that the width of the tarred/cement runover across the pavement to the road kerb and presumably the width of the kerb dropdown must match the proposed increased width of your drive? I assume if you go ahead with the proposed drive widening the council will modify the runover/pavement/kerbing to match and bill you for same. This could be quite expensive since a surface water runoff drain seems to be involved.
OP
OP
Whitey
Whitey
Surbiton, Surrey
Thanks for the comments. The price is relatively high, but for ease of access for reverse parking after a long night shift, I think it is worth it.
That kerbstone and drain cover is a wheel killer !
I will give them a call, if possible, and report back.
Chris
@MARK
Spalding, Lincolnshire
Audi A7 Quattro
I would go back to the council and demand that they reissue their letter in PROPER ENGLISH!
There is no excuse for a council to be sending out this sort of rubbish to members of the public and is simply laziness on behalf of the person that wrote the letter
OP
OP
Whitey
Whitey
Surbiton, Surrey
^ I am glad I'm not the only one who thinks the statement isn't clear !
Proper English, love it.
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
I have seen driveways with no kerb dropdown on the roadside - on one occasion I even saw the entrance 'blocked' by residents parking bay (though the locals obviously new better than to park there) - I wonder if the council is concerned about home owners saving on costs relating to the council's pavement work ?
OP
OP
Whitey
Whitey
Surbiton, Surrey
In some places I have seen 'decorative' bollards placed onto the pavement to prevent access as you describe.
They allow you to pay in 10 instalments to help with the outlay.
BTB 500
MB Club Veteran
Berkshire
R129 SL500, W639 Vito 120, S203 C230
I think that's exactly what it means.
The pavement is dug up, strengthened, and re-laid in line with the new dropped kerb - if the actual entrance to your property is wider then you may drive over unstrengthened pavement on the way in or out.
Harrythedog
Tynemouth
GLC 250 Sport Premium+
I'd just do what you'd like to be done and tell the council you've followed their letter verbatum
OP
OP
Whitey
Whitey
Surbiton, Surrey
Yup, new owner.
a) the garden is stripped bare now
b) I wouldn't drive a red Mini !
grumpyoldgit
Stourbridge
C270CDI Avantgarde SE
I agree with w124nut's interpretation of the wording. Obviously the drain would need to be changed for a grid type, instead of a kerb type. You may also need planning permission to demolish part of your wall in order to widen the driveway opening. I'm pretty sure that you can't just completely remove a front wall, but not sure on any alterations to it. (Assuming you take the legit route). You say that you've stripped the garden now, be aware of the legislation regarding rainwater drainage/run off of the surface if planning to change it.
OP
OP
Whitey
Whitey
Surbiton, Surrey
Thanks for the info.
You are right about the drain, it is going to be changed - the biggest cost.
I am going to create a 'rain garden' to collect water as well as using the existing soak away.
MOCAŠ
West London
SLK
Bit of an over-reaction? All it's missing is a comma and a couple of hyphens (and perhaps they could have said "pavement" rather than "footway", and "must not" rather than "cannot"):
"to prevent overrunning and damage to the footway, the width of the new or widened crossover cannot be less than the width of the back-of-footway entrance onto your property"
OP
OP
Whitey
Whitey
Surbiton, Surrey
"to prevent damage to the pavement, the width of the new or widened crossover cannot be less than the width of the entrance onto your property"
