Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
nickmannThis means if you put the lever in R on the motorway then the box will select R. HOWEVER said:To add a bit more detail, the reverse interlock is a solenoid on the side of the shift gate controlled by the ECU and the shift to R are ignored above 5mph. Also the revs are limited to 1200rpm if the vehicle is moving more than 5mph in the wrong direction.
