Mr-Goose
- May 25, 2017
- E350 Coupé
I picked up a 2012 e class coupe the other day. I absolutely love the car. The audio system sounds good but I wish it had DAB.
I think it has ntg 4.5. It has an SD card reader in the dash and USB in the centre console alongside an MMI socket. I would like to add a DAB receiver and interface with an iPod. I can read audio files from the SD card but I have some very long tracks (ranging from 30 to 180 minutes). Using the iPod in my old car it would remember the last played position. This car doesn't do that when playing from the SD card (does when turning off/on but can't change tracks and come back to previous point later). I have an MMI iPod cable on order and I presume it will support that since the iPod will handle it again.
The DAB solutions I'm considering are the Pure Highway 400 (supports Spotify too) or the denison USB connected device. I don't want to use the FM transmitter as I have found these to be a little unreliable in the past (long time ago). It can be connected through a 3.5mm jack but that means I would need to swap MMI cables. Has anyone used the pure 400 with fm? Is the quality good (I'm no audiophile)? Is the denison any good? I've never tried a dab to USB solution before.
The comand unit does list an AUX interface already (not greyed out). Is there a hidden input somewhere that I don't know about?
Are there any other solutions you guys have used? I don't want to use my phone with Bluetooth. I want something with more physical controls, not a tiny smartphone interface (while I'm driving).
I have considered a homebrew option using a raspberry pi but I can't find a cheap DAB module to test with.
