GingerWeegie
I've a 1999 E200 avantgarde which has sod all air emiting from it's vents, even when the blower is set to 5 (highest setting). I can hear the fan working furiously, but little or no air comes out any of the vents. Then there's the very small point that, seeing as it's been a bit hot, the AC doesn't seem to do very much in the way of cooling the air.
Is this a common problem and is there a simple, quick fix, or do I need specialist help?
