starfinder
- Oct 22, 2004
Hi Guys, :bannana:
Need some advice before bringing my car to the local MB dealer for diagnostics.
Car: E220 CDI MY 2001, Automatic
For the past month or so I have noticed that the engine frequently runs a little rough at idle, not much but still perceivable. When this happens the charging voltage start to fluctuate between 12-13V (read out on the climatic control display by pressing the ‘rest’ button and selecting menu 24).
I have not yet got a charging warning, but as a electronics engineer it seems strange that the voltage fluctuate so much. When the engine runs smooth at idle the voltage is stable at 13.3V.
Have anyone experienced something like this or just any good ideas! – Is it likely that a worn generator or defect regulator can cause this idle problem or is it more likely something to do with the defect injector/ high pressure pump drawing too much current, i.e. forcing the voltage to fluctuate? The car starts without any problems!
I have also noticed another strange thing! - When engine is cold (just started) and I stop at a red light (engine still very cold), the whole car seems to shake forth and back at idle. When pulling away at green light, the car seems to run for a longer time in 1.gear than usually before shifting up. - Is this due to some emission related thing for CDI cars, and normal?
Not a problem when engine is hot or has been running from cold for more than 5min.
BR
Starfinder
BR
Starfinder
